Tabelle Classificazione Materiali - Tabelle e Materiali
titone78
Messaggio da titone78 » 6 mar 2013, 23:34
ciao voglio postarvi le tabelle sulle classificazione dei materiali.......incominciamo con l'acciao inox.....piu avanti parleremo dell'acciaio al carbonio,rame ottone e tutti gli altri tipi......[img]http://imageshack.us/a/img202/4149/16781222.jpg[/img][img]http://imageshack.us/a/img839/6849/245apage3.jpg[/img][img]http://imageshack.us/a/img13/3892/245apage4.jpg[/img][img]http://imageshack.us/a/img29/1851/245apage6.jpg[/img][img]http://imageshack.us/a/img692/1706/245apage7.jpg[/img][img]http://imageshack.us/a/img541/3456/245apage8.jpg[/img][img]http://imageshack.us/a/img826/3797/245apage9.jpg[/img][img]http://imageshack.us/a/img688/2559/245apage10.jpg[/img][img]http://imageshack.us/a/img823/2665/245apage11.jpg[/img][img]http://imageshack.us/a/img109/6640/245apage12.jpg[/img][img]http://imageshack.us/a/img547/7714/245apage13.jpg[/img][img]http://imageshack.us/a/img9/1166/245apage14.jpg[/img][img]http://imageshack.us/a/img17/1286/245apage15.jpg[/img][img]http://imageshack.us/a/img96/1796/245apage16.jpg[/img][img]http://imageshack.us/a/img194/9413/245apage17.jpg[/img][img]http://imageshack.us/a/img194/4342/245apage18.jpg[/img][img]http://imageshack.us/a/img837/7370/245apage19.jpg[/img][img]http://imageshack.us/a/img40/7889/245apage20.jpg[/img][img]http://imageshack.us/a/img51/5461/245apage21.jpg[/img][img]http://imageshack.us/a/img713/917/245apage22.jpg[/img][img]http://imageshack.us/a/img836/8837/245apage23.jpg[/img][img]http://imageshack.us/a/img163/1141/245apage24.jpg[/img][img]http://imageshack.us/a/img20/3326/245apage25.jpg[/img][img]http://imageshack.us/a/img24/7865/245apage26.jpg[/img]annoianti ma utili........
Messaggio da Arex » 7 mar 2013, 21:22
Come sempre un'ottimo lavoro titone! Bravo!
titone78
Messaggio da titone78 » 7 mar 2013, 23:36
Ciao a tutti,dopo l'acciaio inox parliamo del ferro o piu giustamente di acciaio al carbonio o legato......parliamo delle sue proprieta e delle sue sigle......posto tutto questo da un libro che ho in casa......se ci sono errori correggetemi......[img]http://imageshack.us/a/img16/4990/tutori.jpg[/img]Proprietà tecnologicheFusibilità E` la proprietà di dare origine a pezzi (getti)sani, compatti senza difetti e alterazioni (ad esempio sono facilmente fusibili la ghisa e il bronzo, difficilmente fusibili l'acciaio).Malleabilità E` l'attitudine del materiale a ridursi in lamine sottili; normalmente i metalli sono più malleabili a caldo che a freddo.Duttilità E` l'attitudine di un materiale a ridursi in fili sottili.Saldabilità E` la proprietà che ha un materiale di unirsi in un solo pezzo con un altro, uguale odiverso.Temprabilità E` l'attitudine ad aumentare la propria durezza per mezzo di particolari trattamenti termici.Proprietà meccanicheResistenza alla trazione: un corpo è sollecitato a trazione quando una forza applicata tende ad allungarlo; il pezzo, prima di rompersi, si allunga in misura tanto più notevole quanto più il materiale è plastico.Resistenza alla compressione: un corpo è sollecitato a compressione quando la forza applicata tende ad accorciarlo; il pezzo s'accorcia invece di allungarsi.Resistenza alla flessione: un corpo è sollecitato a flessione quando le forze applicate perpendicolarmente al suo asse tendono a curvarloResistenza alla torsione: un corpo è sollecitato a torsione quando le forze applicate tendono a torcere le sue fibre.Resistenza al taglio: un corpo è sollecitato al taglio quando le forze applicate tendono a far scorrere uno sull'altro due piani vicini.Durezza: è la resistenza che il materiale oppone alla penetrazione di una punta cioè alla scalfitura (e non alla facilità che ha un minerale di rompersi!).Resistenza a fatica: è la resistenza dei materiali a sforzi variabili e ripetuti (ad esempio, l'accorciamento e l'allungamento di una molla ripetuto per migliaia di volte)Proprietà fisico-chimichePeso specifico: si definisce peso specifico il rapporto tra il peso di un corpo ed il suo volume. Sono detti metalli leggeri quelli che hanno p.s. inferiore a 4 Kg / dm³, metalli pesanti tutti gli altri.Dilatazione termica: i materiali metallici,ognuno in quantità diversa, subiscono un aumento di volume quando vengono riscaldati.Temperatura di fusione: la fusione è il passaggio dallo stato solido a quello liquido: ogni materiale metallico ha un suo caratteristico punto di fusione.Conducibilità termica: è la proprietà dei materiali di trasmettere il calore.Conducibilità elettrica: è la proprietà dei materiali metallici di trasmettere la corrente elettrica.Resistenza alla corrosione: è la proprietà di resistere al deterioramento superficiale causata da reazioni chimiche. Ad esempio gli acciai inossidabili non sono attaccati dalla corrosione (la ruggine del ferro).I materiali ferrosiI metalli sono caratterizzati da una particolare struttura cristallina per cui gli elettroni non sono rigidamente associati ai nuclei nei rispettivi atomi, ma sono liberi di muoversi. Questa caratteristica determina elevata conducibilità elettrica e termica. A temperatura ambiente si presentano allo stato solido; hanno elevato peso specifico, sono malleabili, duttili e opachi. I metalli puri vengono usati poco, sono più usate le leghe. Gli elementi metallici sono molto numerosi, fra i più importanti ricordiamo il ferro, il rame, l'alluminio, lo zinco, il piombo, lo stagno, l'argento, l'oro.Il FerroIl ferro puro è di colore bianco-argenteo, è duttile e malleabile. Fonde a circa 1808 °C, bolle a 3023 °C, ha peso specifico 7,86 Kg/dm3 e peso atomico 55,847.Il CarbonioIl carbonio ha peso atomico 12,01 ed esiste in natura in tre forme caratterizzate da diversa struttura cristallina: il diamante,la grafite e il carbonio amorfo.Queste formehanno punti di fusione estremamente alti.I più comuni fra i suoi composti sono quelli che contengonocarbonio e idrogeno (idrocarburi).Il carbonio è poco reattivo a temperatura ambiente, ma a temperature elevate reagisce facilmente con molti metalliper formare i carburi, e con l'ossigeno per formare il monossido di carbonio (CO) e il diossido di carbonio, noto anche come anidride carbonica (CO2).La GhisaLe ghise sono leghe ferro-carbonio con percentuali di carbonio che in pratica vanno dal 1,7% al 4,5%. La Ghisa è dura, fragile, resiste poco alla trazione e alla flessione, è resistente alla compressione e alla corrosione, non può subire lavorazioni plastiche inquanto non è malleabile, né a caldo né a freddo, possiede un'ottima fusibilità, fonde a temperatura non molto elevata, è fluida, dà getti sani e compatti e consente una facile realizzazione di pezzi anche molto complicati. Le ghise si suddividono in ghise grezze, ottenute direttamente dall`altoforno e ghise di qualità, ottenute dalla lavorazione di ghise grezze.Tipi di ghise:Ghisa sferoidale , così chiamata in quanto il carbonio è presente sotto forma di piccole sfere la cui formazione è provocata dall`aggiunta di magnesio. Contiene anchesilicio, manganese, nichel, fosforo e zolfo. Possiede caratteristiche simili agli acciai. Viene utilizzata per ingranaggi, ruote, ecc.Ghise aciculari , così chiamate per la struttura ad aghi che assicura una grande resistenza agli urti. Contengono anche silicio, manganese, fosforo e zolfo.I Leganti delle GhiseNichel: elemento grafitizzante, abbassa i punti critici di trasformazione, migliora le caratteristiche meccaniche, dà saldabilità e resistenza alle alte temperature ed agliambienti corrosiviCromo: elemento antigrafitizzante, viene introdotto assieme al nichel per contrastare la formazione di grafiteMolibdeno: tampona l`azione grafitizzante del nichel,favorisce l`azione aciculare della grafite e dà quindi resistenza agli urti.L`AcciaioL'Acciaio è una lega di ferro e carbonio che contiene una percentuale di carbonio inferiore al 2% e più di altri elementi come silicio, manganese, zolfo efosfor o.Le proprietà dei vari tipi di acciaio dipendono principalmente dalla quantità di carbonio presente, che ne condiziona la temprabilità, e dalla sua distribuzione nel ferro, dalleferroleghe aggiunte e dai trattamenti termici subiti. Generalmente presentano buone proprietà meccaniche e sono lavorabili per deformazioni plastiche e con lemacchine utensili; sono facilmente saldabili. L`acciaio viene commercializzato in una grande varietà di tipi, ciascuno con caratteristiche diverse, classificabilisecondo la composizione chimica, la struttura, il processo di produzione, l'impiego prevalente. Una classificazione molto comune distingue cinque grandi categorie:Acciai al carbonioCostituiscono oltre il 90% di tutti gli acciai e contengono una quantità variabile, generalmente inferiore all'1,5%, di carbonio, un massimo di 1,65% di manganese, lo 0,60% di silicio e lo 0,60% di rame. Secondo il tenore o percentuale di carbonio, si dividono in: acciai extradolci (meno dello 0,15%) dolci (da 0,15% a 0,25%)semiduri (da 0,25% a 0,50%) duri (oltre lo 0,50%) Gli acciai extradolci e dolci sono comunemente indicati come ferro.Acciai legatiSono caratterizzati dalla presenza di quantità variabili di uno o più elementi quali vanadio, molibdeno, manganese, silicio, rame in percentuali superiori a quelle contenute negli acciai al carbonio. Gli acciai legati vengono usati nella produzione di molti componenti meccanici: bielle, alberi, perni, sterzi, assali dei veicoli,ecc.Acciai debolmente legati ad alta resistenza Rappresentano la più recente categoria di acciai e sono noti con la sigla HSLA (acronimo di high-strength low- alloy). Contengono solo piccole quantità di altri elementi quali, ad esempio, vanadio, e dunque sono in generale più economici dei normali acciai legati; vengono prodotti con particolari procedure, capaci di conferire loro una resistenza meccanica, anche alle basse temperature, e una resistenza alla corrosi one superiori a quelle degli acciai al carbonio.Acciai fortemente legati (inossidabili) Contengono cromo (in quantità variabile tra il 12% e il 30%), nichel (fino al 35%) e altri elementi leganti, che li rendono brillanti e li proteggono dall'attacco degli agenti atmosferici e di gas e acidi corrosivi. Presentano una resistenza meccanica non comune. Trovano impiego nella realizzazione di tubature e serbatoi di raffinerie petrolifere e impianti chimici, di aerei a reazione ecapsule spaziali, di apparecchiature e strumenti chirurgici, di protesi dentarie e chirurgiche. Molto diffuso l'impiego nella produzione di pentolame, posate eutensili da cucina.Acciai da utensili Si usano per produrre la maggior parte degli utensili per lavorazioni meccaniche. In particolare, sono detti acciai rapidi quelli che contengono tungsteno, molibdeno e altri elementi leganti che ne aumentano la resistenza all'usura in lavorazioni ad alta velocità; extrarapidi o super-rapidi quelli che contengono anche cromo.I Leganti dell`AcciaioNichel,Silicio, Manganese : aumentano resistenza e tenacità. In particolare il Silicio viene spesso adoperato nelle resistenze elettriche e per la costruzione di mollepoiché aumenta la resistenza Ohmica.Cromo, Molibdeno, Vanadio : formano carburi, quindi migliorano le caratteristiche meccaniche, ma innalzano i punti critici quindi ostacolano la temprabilità. Inparticolare il Molibdeno viene inserito negli acciai da costruzione poiché riduce la fragilità di rinvenimento.Trattamenti termici degli acciaiGli acciai, trattati con il calore, acquistano modificano o migliorano alcune caratteristiche meccaniche e tecnologiche. Ricordiamo alcuni tra i principali trattamenti termici:La tempra che si esegue riscaldando il metallo fino alla temperatura di 760-850 °C e quindi raffreddandolo rapidamente in acqua o in olio: il brusco raffreddamentoconferisce durezza, ma questo processo crea nel metallo cospicue tensioni e deformazioni interne, che lo rendono più fragile. Questo trattamento è però fortemente influenzato dalla velocità con la quale avviene il raffreddamento poiché lastruttura dell` acciaio ne risu lta fortemente influenzata. Infatti nel caso in cui la velocità di raffreddamento sia ragionevole( 1/100°C al sec) non si hanno sostanziali i cambiamenti rispetto a quanto previsto dal diagramma ferro- carbonio se non delle lamelle di cementite più fini. Aumentando non di molto la velocità l`effetto è quello diformazione di cementite con reticoli di ferro alfa distorti, il che porta ad una struttura, detta Bainite, che ha delle caratteristiche meccaniche medio-buone. Ultimo e più importante caso è quello di raffreddamento ad elevata velocità che comporta la formazione di martensite, una particolare struttura da lle elevate caratteristichemeccaniche quali resistenza e durezza. Basti pensare che la durezza di un acciaio è determinata dalla percetuale di martensite in esso contenuta. I difetti della tempra si possono eliminare con il rinvenimento che consiste nel riscaldare nuovamentel'acciaio a temperatura più bassa, raffreddandolo poi rapidamente. Il rinvenimento diminuisce la durezza e la resistenza dell'acciaio e ne accresce la duttilità e latenacità. La sequenza tempra-rinvenimento prende il nome di bonifica.La ricottura elimina totalmente gli effetti della tempra, conferendo la massima omogeneità e malleabilità all'acciaio. In questo caso si riscalda l'acciaio a temperatura elevata raffreddandolo però lentamente a temperatura ambiente.La normalizzazione consiste nello scaldare l'acciaio a temperatura relativamente bassa, lasciandolo poi raffreddare in aria; ha lo scopo di eliminare le tensioniinterne indotte da lavorazioni di fucinatura e di omogeneizzare la struttura dei getti di fusione.La nitrurazione è invece un trattamento definitivo che non necessita tempra ed ha loscopo di far raggiungere all`acciaio elevatissima durezza facendo formare nitruri insuperficie (1200HV). Il trattamento viene effettuato ad una temperatura di 550°C circa. L`Azoto, monoatomico, che entra nel metallo non si diffonde in superficie, ma forma nitruri in superficie.tempra superficiale è un trattamento termico che prevede la trattazione di un acciaio con elevato tenore di carbonio e già bonificato che viene sottoposto ad un elevato gradiente di temperatura in modo da austenitizzarne completamente la superficie che va poi bruscamente raffreddata con lo scopo di ottenere martensite in superficie mantenendo tenacità nel nucleo. Nomenclatura degli AcciaiGli acciai possono essere definiti in base a:Proprietà meccaniche garantite(1)Composizione chimica(2)In base alla composizione chimica poi si dividono in:Acciai al carbonio(3)Acciai legati(4)E gli acciai legati ancora in:Debolmente legati( acciai da costruzione)(5)Fortemente legati (acciai speciali)(6)(1) In genere sono acciai per i quali non è previsto trattamento termico. Contengono quantità di carbonio dallo 0.10% allo 0.22%, non ne si conosce esattamente la composizione, sono indicati con la siglaFeseguita da un valore numerico che ne indica la resistenza a rottura garantita:Fe 410indica un acciaio con limita di rottura di 410N/mm(2) Se il simbolo Fe è seguito dalla lettera E significa che il numero indica il carico di snervamento:Fe E 210Se il numero è seguito da una le ttera dalla A alla D essa ne indica attitudine alla saldatura(D migliore, A peggiore):Fe 410 BSe Fe è seguito dalla lettera P e poi da un numero, la sigla indica l`imbutibilità:Fe P 02(3)Per gli acciai al carbonio la nomenclatura prevede una lettera C seguita dalla percentuale di carbonio moltiplicata per 100:C 40designa un acciaio con 0.4 % di carbonio Accia da cementazione ne esistono solo 2:C10, C15C100 e C120sono acciai da utensiliC50sono acciai da bonifica(5)Per gli acciai debolmente legati la nomenclatura prevede un numero che indica la % di carbonio moltiplicata per 100, seguito da tutti i leganti che sono presenti in quantità maggiori ad un limite caratteristico. Il numero finale indica la % del primo legante moltiplicata: per 4 per Cr, Ni per 10 per Mo per 1000 per B40NiCrMo716CrNi4Il Manganese viene indicato nella sigla solo se in % maggiore allo 0.8% Se la sigla è seguita da KU allora l`acciaio è da utensile:16CrNi4 KU(6) Un acciaio viene ritenuto fortemente legato se un elemento è presente in quantità superiore al 5%. Per tali acciai la nomenclatura prevede una X davanti alla sigla, la % di carbonio moltiplicata per 100 poi gli elementi leganti seguiti dal le loro % in due numeri:X10CrNi 18-08X10CrNi 18-10Il numero dopo la sigla sigla è presente solo se la % di un dato elemento supera il 5%:X40CrMo 05spero possa esser utile ciao
Messaggio da Arex » 7 mar 2013, 23:41
Interessante, molto interessante ...
valtersecondo
Messaggio da valtersecondo » 8 mar 2013, 21:26
Grazie, molto interessante.
itsservice
Messaggio da itsservice » 8 mar 2013, 21:58
Dati Utilissimi ed interessantissimi!!!!!
titone78
Messaggio da titone78 » 8 mar 2013, 23:39
ciao bene.....son contento che intaressa......con il tempo approfondiremo l'argomento di questo e di altri materiali......
titone78
Messaggio da titone78 » 11 mar 2013, 17:48
proseguiamo con questo discorso......questi sono i vari minerali che possiamo avere nei nostri acciai,con elencati pregi e difetti nelle lavorabilita meccanicaElementi legantiC influisce sulla durezza (con un tenore maggiore si ha un aumento dell`usura per abrasione). Con un basso tenore di carbonio, inferiore allo 0,2%, si ha un aumento dell`usura per adesione, con conseguente formazione di tagliente di riporto e controllo truciolo insoddisfacente.Cr, Mo, W, V, Ti, Nb (formatori di carburi)) determinano un aumento dell`usura da abrasione.O influisce notevolmente sulla lavorabilità: genera inclusioni non metalliche, ossidiche ed abrasive.Al, Ti, V, Nb sono impiegati come trattamenti a grana fine sull`acciaio, che lo rendono più tenace e difficile da lavorare.P, C, N nella ferrite, determinano una diminuzione della duttilità, con conseguente aumento dell`usura per adesione.Effetto positivo Pb nell`acciaio facilmente lavorabile (con punto di fusione basso) riduce l`attrito tra truciolo e inserto, riduce l`usura e migliora il controllo truciolo.Ca, Mn (+S) formano solfuri teneri con azione lubrificante. Un elevato tenore di zolfo (S) migliora la lavorabilità e il controllo truciolo.Lo zolfo (S) influisce positivamente sulla lavorabilità: anche le più piccole differenze nell`ordine dello 0,01% e 0,03% possono incidere notevolmente sulla lavorabilità. Questi effetti sono sfruttati negli acciai facilmente lavorabili. Di norma il tenore di zolfo si aggira intorno allo 0,25%. Lo zolfo determina inclusioni tenere di solfuro di manganese (MnS), che vanno a costituire uno strato lubrificante tra il truciolo e il tagliente. Il MnS migliora anche il controllo truciolo. Il piombo (Pb) ha un effetto analogo, ed è spesso utilizzato insieme allo zolfo (S) in acciai facilmente lavorabili in quantità che si aggirano intorno allo 0,25%.Effetti sia positivi sia negativiSi, Al, Ca formano inclusioni di ossidi che determinano un aumento dell`usura.Le inclusioni nell`acciaio hanno una notevole influenza sulla lavorabilità, anche se sono presenti in percentuali molto ridotte della composizione totale. Questa influenza può essere sia negativa che positiva. L`alluminio (Al), ad esempio, è utilizzato per deossidare la colata di ferro. Tuttavia, l`alluminio forma dell`ossido di alluminio fortemente abrasivo (Al2O3), che ha un effetto dannoso sulla lavorabilità (a confronto con il rivestimento di allumina di un inserto). Questo effetto negativo, tuttavia, può essere contrastato con l`aggiunta di calcio (Ca), che va a formare un guscio tenero attorno alle particelle abrasive. L`acciaio fuso ha una struttura superficiale ruvida, che può comprendere inclusioni di sabbia e scorie, pertanto il tagliente dovrà avere un`elevata tenacità. L`acciaio laminato è caratterizzato da una grana abbastanza grossa, che rende la struttura irregolare, provocando variazioni nelle forze di taglio. L`acciaio forgiato ha una grana più fine e una struttura più uniforme, che determina meno problemi durante il taglio.
titone78
Messaggio da titone78 » 11 mar 2013, 18:03
Altre tabelle su gli acciai......[img]http://imageshack.us/a/img689/2356/acciai1.jpg[/img][img]http://imageshack.us/a/img266/563/acciaiutensili.jpg[/img][img]http://imageshack.us/a/img96/856/acciaisleghe.jpg[/img]
Torna a “Tabelle e Materiali”
