Tornio e Utensili - Uso Attrezzatura
titone78
Messaggio da titone78 » 12 mar 2013, 16:35
ciao a tutti,voglio postare questa guida riguardo il tornio,il suo uso e le sue lavorazioni....logicamente questa e una guida per chi incomincia,ma forse c'e qualche consiglio anche per i piu esperti......lo scannerizzata quindi la guida e tutta in formato jpg[img]http://imageshack.us/a/img690/4083/iltorniopage1.jpg[/img][img]http://imageshack.us/a/img515/1773/iltorniopage2.jpg[/img][img]http://imageshack.us/a/img199/213/iltorniopage3.jpg[/img][img]http://imageshack.us/a/img856/4350/iltorniopage4.jpg[/img][img]http://imageshack.us/a/img195/7017/iltorniopage5.jpg[/img][img]http://imageshack.us/a/img18/4547/iltorniopage7.jpg[/img][img]http://imageshack.us/a/img407/980/iltorniopage8.jpg[/img][img]http://imageshack.us/a/img255/9010/iltorniopage9.jpg[/img][img]http://imageshack.us/a/img69/7386/iltorniopage10.jpg[/img][img]http://imageshack.us/a/img849/7358/iltorniopage11.jpg[/img][img]http://imageshack.us/a/img560/4846/iltorniopage12.jpg[/img][img]http://imageshack.us/a/img571/5457/iltorniopage13.jpg[/img][img]http://imageshack.us/a/img248/6452/iltorniopage14.jpg[/img][img]http://imageshack.us/a/img835/3748/iltorniopage15.jpg[/img][img]http://imageshack.us/a/img32/7731/iltorniopage16.jpg[/img][img]http://imageshack.us/a/img849/6527/iltorniopage17.jpg[/img][img]http://imageshack.us/a/img685/6838/iltorniopage18.jpg[/img][img]http://imageshack.us/a/img22/6308/iltorniopage19.jpg[/img][img]http://imageshack.us/a/img194/8901/iltorniopage20.jpg[/img][img]http://imageshack.us/a/img850/4069/iltorniopage21.jpg[/img][img]http://imageshack.us/a/img441/1987/iltorniopage22.jpg[/img][img]http://imageshack.us/a/img580/7725/iltorniopage23.jpg[/img][img]http://imageshack.us/a/img6/796/iltorniopage24.jpg[/img][img]http://imageshack.us/a/img824/6025/iltorniopage25.jpg[/img][img]http://imageshack.us/a/img802/5811/iltorniopage26.jpg[/img][img]http://imageshack.us/a/img827/7834/iltorniopage27.jpg[/img][img]http://imageshack.us/a/img213/7671/iltorniopage28.jpg[/img][img]http://imageshack.us/a/img13/7139/iltorniopage29.jpg[/img][img]http://imageshack.us/a/img826/1848/iltorniopage30.jpg[/img][img]http://imageshack.us/a/img685/8123/iltorniopage31.jpg[/img][img]http://imageshack.us/a/img844/8537/iltorniopage32.jpg[/img][img]http://imageshack.us/a/img208/2635/iltorniopage33.jpg[/img][img]http://imageshack.us/a/img560/2117/iltorniopage34.jpg[/img][img]http://imageshack.us/a/img254/2017/iltorniopage35.jpg[/img][img]http://imageshack.us/a/img442/5113/iltorniopage36.jpg[/img][img]http://imageshack.us/a/img442/1985/iltorniopage37.jpg[/img][img]http://imageshack.us/a/img844/921/iltorniopage38.jpg[/img][img]http://imageshack.us/a/img268/9461/iltorniopage39.jpg[/img][img]http://imageshack.us/a/img834/9106/iltorniopage40.jpg[/img][img]http://imageshack.us/a/img195/7863/iltorniopage41.jpg[/img][img]http://imageshack.us/a/img571/4492/iltorniopage42.jpg[/img][img]http://imageshack.us/a/img854/3339/iltorniopage43.jpg[/img][img]http://imageshack.us/a/img713/2777/iltorniopage44.jpg[/img][img]http://imageshack.us/a/img18/1128/iltorniopage45.jpg[/img][img]http://imageshack.us/a/img841/5994/iltorniopage46.jpg[/img][img]http://imageshack.us/a/img819/4187/iltorniopage47.jpg[/img][img]http://imageshack.us/a/img6/8956/iltorniopage48.jpg[/img][img]http://imageshack.us/a/img837/4860/iltorniopage49.jpg[/img][img]http://imageshack.us/a/img854/6370/iltorniopage50.jpg[/img][img]http://imageshack.us/a/img845/847/iltorniopage51.jpg[/img][img]http://imageshack.us/a/img404/3584/iltorniopage52.jpg[/img][img]http://imageshack.us/a/img811/3088/iltorniopage53.jpg[/img]scusate la lunghezza... ma dato la completezza della guida mi sembrava un delitto tagliarla......ciao
marcobr
Re: Tornio e Utensili - Uso Attrezzatura
Messaggio da marcobr » 5 giu 2015, 23:03
Ho scelto questa zona per una domanda : come si taglia una barretta di "utensile da tornio" ???
Ho provato con il flessibile con un disco da 1 mm e si riesce a tagliare ma surriscalda molto la barretta.
Messaggio da Arex » 6 giu 2015, 0:43
Anche io taglio con disco ... poi la parte che si scotta la togli pian piano tenendo il materiale basso di temperatura....
marcobr
Messaggio da marcobr » 6 giu 2015, 22:06
Ne devo fare 45 pz con barrette 14x14 . 2 cm di lunghezza da saldare su un rullo per grattugiare un po di tavole
Messaggio da Arex » 6 giu 2015, 22:36
Ahi .... un lavoraccio ..... ci va pazienza...
marcobr
Messaggio da marcobr » 7 giu 2015, 23:11
Ne ho tagliato uno e mi è già passata la voglia figurati arrivare a 45 e senza sapere se ne valga la pena perdere tempo e materiale.
Messaggio da jpquattro » 10 giu 2015, 12:52
premesso che 14x14 è un po' grosso per spezzarlo preciso a martellate...
Un tentativo lo puoi fare.
- metti 2 viti senza testa (o due chiodi, o due rullini di qualche tipo...) vicine, appoggiate su un supporto solido (morsa o incudine...)
- appoggia la barretta sulle viti con la riga in cui deve avvenire il taglio al centro fra le due viti
- prendi uno scalpello per metalli, appoggialo dove vuoi la rottura (sotto ci debbono essere le viti, una di qua e una di la dalla rottura desiderata)
- martello e colpo secco. e opportuno predisporre un qualche contenimento per impedire che i due pezzi schizzino a giro per l'officina...
Messaggio da Arex » 10 giu 2015, 12:59
Ahi .... ho paura che spezzare una barra quadrata da 14mm x 14mm in hss con una martellata sia davvero dura ....
Torna a “Uso Attrezzatura”
