Salve come da titolo cedo INVERTER SOLAR 2400W 24V 3000VA ONDA PURA CON REGOLATORE DI CARICA 70A, nuova mai usata prezzo vero affare € 310 questi sono i requisiti della turbina come da venditore su Ebay SIAMO AUTORIZZATI RIVENDITORE PORTANDO UN SACCO DI BUONA QUALITÀ PRODOTTI SOLARI DA LIFE & WELFARE CO.,LTD. IN TAIWAN.
HIGH-EFFICIENCY HYBRID / OFF-GRID
SOLAR INVERTER WITH 70A Max. Charge Current (PWM) SERIES
3000VA/2400W DC 24V ( PWM )
Max. Charge Current 70A , P3000-24
HYBRID / OFF-GRID is a multi-function inverter/charger, combining functions of inverter, solar charger and battery charger to offer uninterruptible power support with portable size. Its comprehensive LCD display offers user-configurable and easy-accessible button operation such as battery charging current, AC/solar charger priority, and acceptable input voltage based on different applications.
FEATURES
Pure sine wave solar inverter
Selectable high power charging current
Wide DC input range
Selectable input voltage range for home appliances and personal computers
Configurable AC/Solar input priority via LCD setting
Compatible to mains voltage or generator power
Auto restart while AC is recovering
Overload and short circuit protection
Smart battery charger design for optimized battery performance
Cold start function
APPLICATIONS
Residential, Commercial, and Industrial application
Please kindly be advised this inverter is only for AC230V(240V) input / AC230V(240V) output AC power system
( This inverter could not connect directly to a AC 240V/120V split phase power system in USA )
Warranty
•Standard 1 year product warranty
•100% quality check before shipment
•Please kindly be advise that Buyer is responsible for warranty return shipping.
SPECIFICATIONS
Model P3000-24 M3000-24 M3000-24 Plus P5000-48 M5000-48
RATED POWER 3000VA / 2400W 5000VA /4000W
INPUT
Voltage 230 VAC
Selectable Voltage Range 170-280 VAC (For Personal Computers) ; 90-280 VAC (For Home Appliances)
Frequency Range 50 Hz/60 Hz (Auto sensing)
OUTPUT
AC Voltage Regulation (Batt. Mode) 230 VAC ± 5%
Surge Power 6000VA 10000VA
Efficiency (Peak) 90%~93%
Transfer Time 10 ms (For Personal Computers) ; 20 ms (For Home Appliances)
Waveform Pure sine wave
BATTERY
Battery Voltage 24 VDC 48 VDC
Floating Charge Voltage 27 VDC 54 VDC
Overcharge Protection 32 VDC 60 VDC
SOLAR CHARGER & AC CHARGER
Solar Charger Type PWM MPPT PWM MPPT
Max. PV Array Open Circuit Voltage 80 VDC 102 VDC 145 VDC 105 VDC 145 VDC
Max. Solar Charge Current 50A 40A 60A 50A 60A
Max. AC Charge Current 25 A 60 A
Max. Charge Current 70 A 60 A 120 A 110 A 120 A
PHYSICAL
Dimension, D x W x H (mm) 100 x 334 x 285 100 x 440 x 300
Net Weight (kgs) 6.4 6.6 11 11 13
Communication Interface USB
OPERATING ENVIRONMENT
Humidity 5% to 95% Relative Humidity(Non-condensing)
Operating Temperature -10°C to 55°C
Storage Temperature -15°C to 60°C.
Da premettere che io l'ho comprata € 499 potete vedere su ebay , vorrei cambiarla per eventuale passaggio a 48v , fatemi sapere,grazie.-
- 16406756_1037558749717020_8256477702361005910_n.jpg (143.98 KiB) Visto 7927 volte
- 16388044_1037579823048246_5457971953009308430_n.jpg (111.33 KiB) Visto 7927 volte
- 16387247_1037579476381614_2920358681765943890_n.jpg (117.35 KiB) Visto 7927 volte
- 16386852_1037580099714885_5963173276800079202_n.jpg (127.79 KiB) Visto 7927 volte
- 16265851_1037579656381596_6946946917763205883_n.jpg (142.38 KiB) Visto 7927 volte
Re: INVERTER SOLAR 2400W 24V 3000VA ONDA PURA CON REGOLATORE DI CARICA 70A
Salve ragazzi , vi comunico che l'inverter è già stato venduto.
